Fuse for 12V Block Under Dash?
Old Nov 26, 2006 | 12:11 PM
Zonie's Avatar
Default Fuse for 12V Block Under Dash?
OK, so i hardwired my GPS with a female quick disconnect to the ignition 12V terminal on the block under the dash (photo courtesy of XViper)
My question is this: is this connection fused at the block somewhere? And if so which fuse is it? I could go back and install an inline fuse but I'm too lazy to if I don't need it.
BTW I went through the FAQ but it's so damn long I couldn't find my answer (and I'm not even sure it's in there).
Thanks,
Dave (Zonie)
Old Nov 28, 2006 | 05:57 PM
modifry's Avatar
Honorary Member
Both the "constant" and "ignition" terminals are fused by fuse 42 in the under-hood fuse box. It's a 40 or 50 AMP fuse (can't remember). That's why you should always use an in-line fuse when connecting to these terminals. From this terminal you could short an 18-gauge wire to ground and instead of blowing the fuse it would just melt the wire (in about 2 seconds).
BTW - connector E (lights) is fused by fuse 23, 10 amps.
Old Nov 28, 2006 | 06:53 PM
Zonie's Avatar
I figured it was probably on a healthy fuse, so I actually ran 12 Ga. I'll probably go back and put a 20A inline in. Thx for the help!
Old Nov 29, 2006 | 01:18 PM
trapper's Avatar
[QUOTE=modifry,Nov 28 2006, 09:57 PM]Both the "constant" and "ignition" terminals are fused by fuse 42 in the under-hood fuse box.
kasher_khan
Jan 22, 2018 05:05 PM
CMK
May 30, 2017 06:50 AM
k00leo
Dec 20, 2015 03:43 PM
liret6
Jun 23, 2011 11:55 AM
ChefJ
Feb 12, 2009 05:33 PM
