diff mount leaking?
Old Mar 18, 2007 | 03:57 PM
mikegarrison's Avatar
Default diff mount leaking?
Are the diff mounts liquid-filled? One of mine (driver's side, rear mount) is all wet on the rear face. And it looks like some fluid may have splattered on the trunk pan that faces it.
Damn. Looks like a reasonably big job to replace it.
Old Mar 18, 2007 | 04:15 PM
Slows2k's Avatar
They are liquid filled.
It's a common failure point, the mount has no serviceable seals. If it's leaking the mount has to be replaced to fix it.
Old Mar 18, 2007 | 04:55 PM
It looks like maybe if you remove the rear swaybar you could get it out without having to pull the diff. Is that the case?
Can you do it without pulling the swaybar, even? It looks like there wouldn't be enough room for that.
Old Mar 18, 2007 | 04:57 PM
Stratocaster's Avatar
I you are looking some a replacement, I think I have a few in storage.
Old Mar 18, 2007 | 05:04 PM
At what price? Majestic Honda has them at $56 per.
I'll probably just pull both of them at the same time, as long as I'm in there. But if you don't need to take out the rear sway, maybe I'll just do the one.
Old Mar 18, 2007 | 06:46 PM
Since you know what the sell for new, make me an offer. I am reasonable and need cash to build my project car. Like I said they are in storage. I know I have another set on the rear sub spare I have too.
Old Mar 18, 2007 | 08:13 PM
Slows2k's Avatar
The sway bar doesn't need to be removed, just take the brackets off and let the bar drop. The end links don't need to be removed.
Old Mar 18, 2007 | 10:01 PM
Actually, if it's as easy as Slows says it is, I'm gonna see if the local Honda place has one in stock. If so, I could swap it out before I take it to the track next weekend. I'll let you know if I can't find it locally.
Old Mar 19, 2007 | 08:03 AM
Hopefully they are on the new Honda ordering system. That will get it to you next day.
Old Mar 19, 2007 | 08:53 PM
Project22a's Avatar
http://www.hondaautomotiveparts.com/auto/j...FERENTIAL+MOUNT
Illustrated Parts 2 and 3 right?
jstar
Feb 22, 2016 06:20 PM
nadeem
Jul 9, 2014 09:18 PM
newchapter
Oct 10, 2011 03:34 PM
mr 280z again
15
Apr 16, 2010 03:49 AM
mistaXs2000
Aug 2, 2008 12:05 PM
