Turbo list
Old Mar 28, 2007 | 09:34 PM
s2guru's Avatar
Default Turbo list
i Will be buying a turbo kit this week ( lovefab mini-ni)
manifold,
downpipe,
GT3082R turbo,
IC piping,
650hp intercooler,
Tial 44mm wastegate
50mm BOV,
all fittings and hardware,
intake elbow and AEM dry filter,
AEM EGT
Extras:
AEM EMS 1052 ( maybe 1052u)
AEM fuel regulator
GM 3 bar map sensor
GM 3-way solenoid
Defi Link gauges (boost, EGT, oil pressure
Defi controller
Krank Vent
RC 750cc
RC Injector Wire Clip Set
Hoping 340 whp with this setup
Do i need the 225 fuel pump?
Yes i will be running the stock exhaust for now.
any advices?
Old Mar 28, 2007 | 09:53 PM
BulldogS2's Avatar
injectors? how about considering a ball bearing turbo? interesting about the stock exhaust let us know how that goes.
Old Mar 28, 2007 | 09:55 PM
s2guru's Avatar
o yeah and RC 750cc..
I will have a exhaust shop to make a fitting that goes from 3" to 2.25 ( stock )
what else?
Old Mar 28, 2007 | 10:04 PM
afwfjustin's Avatar
I assume you have a dumptube and injector clips? You might want to relocate your battery, thermotec heat tape, 02+ "banjo bolts", oil pan fitting, oil feed/return lines, A-pillar gauge pod, IC piping, couplers, T-bolt clamps, new clutch...
If you're lowering compression: new head bolts or studs, headgasket
Just some suggestions. Make sure you have an extra 500 dollars sitting around - things pop up at the last minute that you'll need that you didn't think of earlier.
Old Mar 28, 2007 | 10:16 PM
s2guru's Avatar
got it.. i know about the new clutch.. but i'm not going to get a new one right now...
where the heck is the banjo bolt locate.. ? afwfjustin you got pm
Old Mar 28, 2007 | 10:31 PM
Spec_Ops2087's Avatar
Its above the oil pan inside the engine. They are the things that spray oil on the crank(?)
Old Mar 28, 2007 | 10:38 PM
s2guru's Avatar
Spec_Ops2087: thanks for the info...
Old Mar 29, 2007 | 04:27 PM
timg's Avatar
You do need the Walbro 255HP fuel pump.
Tim
Old Mar 29, 2007 | 07:43 PM
BulldogS2's Avatar
I see that you are considering the 1052U, if you get this, will you still need gauges or am i way off?
Old Apr 1, 2007 | 08:00 PM
s2guru's Avatar
bumpp...
Corey Maurer
May 16, 2011 05:19 AM
CFLGPs2k
Feb 16, 2011 05:36 PM
superslows2k
Nov 11, 2009 06:45 AM
NFRTurboTerror
Jul 2, 2007 05:08 PM
hahnn002
Apr 9, 2007 09:56 PM
