Details on control arm mount TSB SN040903?
Old Aug 12, 2007 | 05:54 AM
captain_pants's Avatar
Default Details on control arm mount TSB SN040903?
Can anyone supply more details on the upper control arm mount welding TSB "SN040903 09/01/2004 Popping From Front Wheel Upper Control Arm Mount"
My plan is to have this performed before cracking starts, but not at a Honda dealer. I trust a guy that welds for a living to do more consistent welds than a tech that welds once a month.
Is it only the rear upper mounts that need to be welded? Is it a full perimeter weld or only specific regions? Is it only spot weld reinforcement? I don't want to make a guess and then get protested at Nationals!
Yes, I will be autocrossing the car with R-compounds. Hopefully a LOT!
Old Aug 12, 2007 | 07:07 AM
negcamber's Avatar
Here is an excerpt (looks like the link I had to a pdf is broken):
[QUOTE]
Tech Line Summary Article
Pop noise at front upper control arm mount
Applies To: 2000-2004 S2000
If an oil canning or popping noise is heard when cornering or braking hard, visually inspect the frame rail where the front upper control arm-mounting bracket is spot welded to the frame rail. This problem only occurs to vehicles that have been driven repeatedly on a racetrack or in autocross events. If there is a gap
between the mounting bracket and the frame rail, use the following repair procedure:
Old Aug 12, 2007 | 09:56 AM
Awesome! Thank you! I'll get it stitch welded like in those pictures.
The best part is the "large hammer". I'm surprised they don't have a special part number for that!
iamatlas
Jun 12, 2014 07:59 PM
turbo8765
Aug 13, 2010 11:37 AM
ScottnHeidi
Apr 17, 2008 06:09 PM
touges2000
Aug 15, 2007 02:56 PM
