replacement tires
Old Jan 16, 2001 | 10:38 AM
Gaspasser's Avatar
Not sure if this goes here or Car Talk but,
How wide of tires will fit (or have you been able to install) on the stock S2000 rims? I will be needing to re-tire shortly and would like to try a wider rear tire but am unsure as to the technical implications and limitations of deviating from spec. Any suggestions? I would like to go with larger rims but am generally dismayed by the cost and with changing the stock appearance of my car.
Old Jan 16, 2001 | 10:43 AM
Fito's Avatar
I really don't know if it help you but,
I'll be puting 17" BBS LM wheels 7.5 inches wide in the front and 8.5 on the rear. 215/45-17 front and 245/40-17 on rear. The tire sizes were given to me by BBS directly.
Old Jan 16, 2001 | 10:48 AM
The Reverend's Avatar
For the stock rims, you could fit up to a 245/45 on the rear. I have tried 225/50 on the front and it doesn't fit, but I would imagine a 215/50 would if you're up to trying it. However, I recommend staying with the stock sizes and using S-02's as I have found this combination gives the car the best balance and handling.
Old Jan 16, 2001 | 01:15 PM
CG's Avatar
CG
My second set of tires were Kumho 712's with 225/50's in the front and 245/45's in the rear and they fit with no problems. The reason my 225's fit in the front and Rev's didn't may be because all tires are not created equal. Several of our members have found that our stock 205's are not as wide as you would expect a 205 to be and that our 225's are much wider than expected.
My 3rd set of tires were stock S02's again and they did give me a much better balance of ride and handling. The 2nd set of tires had less grip which allowed much more wheelspin out of turns causing me to have to replace them after just a little over 3300 miles.
Old Jan 16, 2001 | 02:33 PM
Yeah, I have seen a set of race tires with 225/50 front and 245/45 rear that fit a little better than mine did, but it was still bulging out quite a bit. With mine, it just looked downright funny. The stock 225/50's are just too wide for the front rims.
Old Jan 16, 2001 | 02:36 PM
cmnsnse's Avatar
Im going with 245/45 rear Potenze RE730 and 225/50 front, I have them and it looks tight for the front but their specs are said to be able to mount on as small as 6" wheel
Besides the OEM those were the widest tread I could find to fit the stock wheels (within .1" of the others) Ill find out about looks/performance this weekend.
BTW I am checking out tread patterns/contact patches and will have a report for S2000 owners about replacements.
I have already been through BFG Comp T/A, and the Bridgestone Pole Positions, now to try the RE730's
let me specify that the RE730 225/50 r16 are suppoed to be able to be mounted on a 6" wheel and the RE730 245/45 r16 only go down to 7.5"
Old Jan 16, 2001 | 02:50 PM
cdelena's Avatar
I bought Yoko A032R
Old Jan 17, 2001 | 04:05 AM
2kturkey's Avatar
[QUOTE]Originally posted by The Reverend
[B]For the stock rims, you could fit up to a 245/45 on the rear.
Old Jan 22, 2001 | 06:57 PM
cdelena's Avatar
I now have both sets of my new tires. An almost new set of OEM S02
Old Jan 22, 2001 | 08:01 PM
RT's Avatar
RT
Nice pics Chris.
So it looks like the stock stagger is something like 45-50mm (195 vs 245) or the rear is approx 25% wider than frt. Very interesting
So for all you folks running 225's up frt, you do the math (hint 285's) and quit crying about the oversteer.
You brought that shit on your self baby.
[Edited by RT on 01-22-2001 at 10:47 PM]
bogeygolf
Jan 9, 2010 11:49 AM
qorn
Nov 10, 2009 11:10 AM
BeachBum
May 24, 2005 05:00 AM
Officer_down
Jun 18, 2003 04:19 PM
Randman
Dec 2, 2002 02:40 PM
