Hardtop Hassles
Old Oct 27, 2007 | 07:42 PM
ntenseone's Avatar
Default Hardtop Hassles
Ok, so I spring for an OEM top, right? Got it last month. I'm so happy. I put it on the car, kinda did a speedy job of it, but nothing seems to be too much the matter with it, so I leave it and it does great...until last weekend. I guess it managed to shake it's way loose a little. So it started to rattle. In an attempt to solve the problem, I went back in and re-adjusted things to make it fit more snug. Seemed to work great, until I was driving around for about an hour and a half or so, and then it went from snug to undrivable in about 30 mins. I don't understand...I was under the impression that these tops are made to be quiet.
How do I shut this thing up?
Old Oct 27, 2007 | 09:43 PM
S2000Patrick's Avatar
Check the striker plates on the windshield frame. Nearly everyone that has hard and soft top rattles overlooks this area and quite often these are visibly loose. To prevent the bolts from coming loose over and over again use threadlock on the bolts, also grease up all of the rubber weather stripping with Shin-etsu grease. You may still get occasional rattling from the folded soft top now and then but that is normal.
If it is installed correctly, it should very quiet and not rattle.
Old Oct 27, 2007 | 10:08 PM
alejo's Avatar
Originally Posted by S2000Patrick,Oct 27 2007, 10:43 PM
Check the striker plates on the windshield frame. Nearly everyone that has hard and soft top rattles overlooks this area and quite often these are visibly loose. To prevent the bolts from comming loose over and over again use threadlock on the bolts, also grease up all of the rubber weather stripping with Shin-etsu grease. You may still get occasional rattling from the folded soft top now and then but that is normal.
Old Oct 27, 2007 | 10:14 PM
fastD's Avatar
I agree - shin-etsu grease works well.
Old Oct 27, 2007 | 11:44 PM
NNY S2k's Avatar
That probably is part of the problem.
Old Oct 27, 2007 | 11:45 PM
NNY S2k's Avatar
Old Oct 28, 2007 | 04:36 AM
Alexei's Avatar
I had this problem too; fortunately, it is well documented here at S2KI.
As was mentioned, go to the dealer and buy some Shin Etsu silicone lube, then apply it to all the soft black rubber seals on the outside edges of the hard top/windshield where the HT mates to the windshield, body, and around the windows.
You also need to get some EPT Sealant (kind of like foam weather stripping) from the dealer (my dealer just cut off a piece from their roll), if they will not give you any, just PM me and I'll send you some... it doesn't take very much to perform the fix below:
Clickie ---> Squeaks and Rattling Latch Fix
I performed the fix, AND tied down the latch hooks on each side of the lowered soft top with plastic cable ties (rubber bands work too); now my hard top is very, very, quiet - even on the bumpiest roads.
Old Oct 28, 2007 | 01:23 PM
neveronlines2k's Avatar
I agree ^ this shoudl fix your issues right up.
I got new catchers from Hard Top guy and they really tightened things up
Old Oct 28, 2007 | 03:56 PM
way2low01's Avatar
No issues here. I purchased the shin etsu grease and grease it up every couple months or so, helped with the squeaking. But the top itself stays in place, no problems.
gatorbait4me2000
Sep 3, 2013 07:48 AM
sql2
Jun 16, 2013 11:51 AM
Putney
Nov 19, 2010 01:01 AM
dundeelad02GT
Feb 20, 2009 03:30 AM
s2ktimmy
Aug 17, 2008 06:21 PM
