softtop help!
Old Feb 25, 2008 | 10:20 PM
buddhaman's Avatar
Default softtop help!
i have a MY00 and the softtop blackness is fading and is now a brownish color. is there any product out there that can restore its color??
thanks in advance
Old Feb 25, 2008 | 11:00 PM
Millenion LTD's Avatar
raggtop or buy new one
Old Feb 26, 2008 | 07:34 AM
wanabe's Avatar
you can get it new again...
any of these products will work- vinylex, 303 or raggtopp (make sure that you get the vinyl version).
wash the top with your car shampoo and a brush. there are top shampoos- i used to use one that is sold by porsche, but i never found that it did anything that my car shampoo wouldnt do with some elbow grease and a brush. since your top is in bad shape you might have an exception to my rule.
scrub well, rinse and dry completely. once dry, soak a rag (really soak it) with your product choice. rub it in to the top. make sure that there is a lot of product on the top. let it sit for awhile. then buff it off. if its new again then buff it one more time with a clean rag. if its not yet new, repeat the process...
take some pics and post em up (in fact how bout take before pics too and post up your whole process and experience!)
raggtopp from our sponsor's site:
http://www.detailersdomain.com/index.asp?P...ATS&Category=26
be sure to use our code for your discount- s2ki- or just call and ask phil for the discount
Old Feb 26, 2008 | 08:24 AM
buddhaman's Avatar
thanks wanabe,
i try that and keep everyone updated.
Old Feb 26, 2008 | 09:23 AM
ADiSKOTEC's Avatar
Mine is gray now instead of black. The previous owner had it in the sun all day. I have some raggtopp cleaner. Let's see if it works.
Old Feb 26, 2008 | 09:52 AM
wanabe's Avatar
cleaner is fine, but its the protectant that should restore your top
Old Feb 26, 2008 | 09:57 AM
ADiSKOTEC's Avatar
Ok, I have the protectant as well. I'll take it with me. I'm charging my camera battery to take some before and after shots if there is a difference.
Old Feb 26, 2008 | 10:00 AM
shotiable's Avatar
if you use a product such as 303 doesnt is blacken the top as well protect it from UV light that causes it to fade?
i'm an advocate of primary care- prevention... i dont wanna run into a fading soft top
Old Feb 26, 2008 | 10:16 AM
Vanishing Point's Avatar
Even a top on a 2007 model can benefit from these cleaners and protectants. I just cleaned and used 303 afterward, the top looks brand new!
Old Feb 26, 2008 | 04:52 PM
ADiSKOTEC's Avatar
Ok, here's my report so far after using raggtopp cleaner and protectant.
I took the car out and washed it. I used raggtopp cleaner to get rid of any dirt on the top.
I brought the car back home and let it dry, then I generously applied raggtopp protectant.
Before applying raggtopp protectant:
As you can see, my soft top is VERY faded!
After applying raggtopp protectant:
After using the protectant I noticed the top is now a bit darker, not not a major change. Would the 303 product be any different?
