PLEASE HELP me verify my vacuum lines!
Old Jun 30, 2008 | 04:12 PM
S2-3456789-K's Avatar
Default PLEASE HELP me verify my vacuum lines!
i think the shop that installed my clutch may have forgotten to put back a vacuum hose. i got a P0411, and after reviewing the AEM installation guide, i realized that the "lower vacuum hose" was missing. i put one back on, but i'm not completely sure if it's correct.
i've circled the area i'm not sure about.
also, when i took my car back to the shop after i got the CEL, they put this T-line in. i just realized this, and i don't know if this is necessary. it didn't fix the CEL, because it came on again.
should i take this T out?
Old Jun 30, 2008 | 05:51 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The T was a bad idea. It will apply vacuum to the air pump valve all the time.
Does this help?
Old Jun 30, 2008 | 06:03 PM
fatjoe10's Avatar
You should remove that "T" that your shop installed. Verify that the "upper" vacuum hose goes to the manifold and that the "lower" one goes to the secondary air valve. Also, make sure the vacumm lines at the bypass control valve (3rd pic) are not reversed. I hope this helps.
Old Jun 30, 2008 | 06:36 PM
wow, ok, billman & fatjoe thanks a lot! the pictures definitely help. i thought the T was BS, and the lower vacuum hose was missing. i'll go ahead and take T out then. thanks again guys!
Old Aug 23, 2011 | 06:40 AM
MaxxRisk's Avatar
Hi
Is a 4mm DI vacuum hose good for the "upper" vacuum hose?
Old Jun 20, 2017 | 10:13 AM
NebraskaS2k's Avatar
I had my engine replaced and continued to get the 0411 code. using your diagram I was able to correct the routing of the upper and lower hose connections. thanks.
Old Jan 28, 2021 | 11:55 AM
Dustin Bruhn's Avatar
Mine is not correct either and my car won’t go pass 6,000rpm it’s like it it looses full/hits a brick wall. Did you have similar issues?
Stratocaster
Aug 9, 2013 05:07 PM
ChaseBaciles
Sep 26, 2010 09:51 AM
rk604
Feb 16, 2009 07:36 AM
559S2000
May 29, 2008 02:11 AM
attack666
Nov 11, 2007 06:23 AM
