Sponsored by:
Sponsored by: CARiD
CR Wing
Old Feb 14, 2009 | 11:04 AM
H2kBBAP2's Avatar
Default CR Wing
I am assuming that the CR wing will just bolt on like a regular OEM AP2 wing correct? Just want to check.
Old Feb 14, 2009 | 12:20 PM
Back S2k's Avatar
yes
Old Feb 15, 2009 | 02:32 AM
illdiealonlyazn's Avatar
it bolts into the middle, i dont think it'll be like the oem wing. Also i believe that the CR has a different design trunk to better suit the wing. like reinforced.
Old Feb 15, 2009 | 06:59 AM
s2k aok's Avatar
negcamber's Avatar
You'll actually need to cut a couple holes in the reinforcement frame in order to get to the bolts that will hold the wing to the trunk.
Do some searching...I think RadioZero or jphish have some pics posted of their install.
Old Feb 15, 2009 | 06:01 PM
S~Factor's Avatar
The difference, the OEM AP2 wing installs on the outside of the trunk. The CR is towards the middle. The trick with CR is using large washers underneath the trunk. It helps it hold on to the sheet metal of the trunk so it won't fly off when you hit 150 mph.
Old Feb 16, 2009 | 03:59 AM
Ks320's Avatar
Actually ... when there is Typhoon, I am a bit worried that the wing would ripoff
I'm sure it can take the speed when the wind is coming from the front of the car ... but i wonder what happens if the wind is flying left and right in a Typhoon ... hence, I keep the car home if the typhoon's really bad hehe (I have the CR wing)
Old Feb 16, 2009 | 03:05 PM
can't you just buy a CR trunk? i mean thats more cost but i'm sure it'd save you from the typhoon
Old Feb 16, 2009 | 05:21 PM
Revenge's Avatar
What would be a good way to fix the holes if you have the AP1 spoiler.
Old Feb 17, 2009 | 06:10 AM
dparm's Avatar
What's an AP1 spoiler?
