Radio takes a long time to turn on
Old May 2, 2009 | 10:31 PM
mhdelano's Avatar
Default Radio takes a long time to turn on
Hey,
I have an 05 bone stock car, and sometimes the radio takes 5-10 minutes to turn on. I turn the car on, and the radio just doesn't turn on until 5-10 minutes go by, it's the weirdest thing. I was thinking it might be a fuse, but if a fuse is blown wouldn't it just not work at all? Has anyone else had this problem? Is it some feature of the anti-theft thing? Any help is appreciated.
Thanks,
Mat
Old May 3, 2009 | 08:42 AM
oth's Avatar
oth
there is a relay which cuts power to the headunit and accessory power
socket when you start the car. sounds like that relay is sticking - check
whether the accessory socket has power when the headunit isn't working.
The relay itself appears to be under the dash behind the headunit to the
left. I would imagine it's easy & cheap to replace.
Old May 3, 2009 | 04:56 PM
sean2sean's Avatar
yea its the relays.
i had the same problem with my 06. and they replaced two relays. they were blown.
Old May 3, 2009 | 10:55 PM
Mr B's Avatar
When you guys had the problem with the radios, did the anti-theft light blink every so often? That's what happens to mine each time I turn off the car and the radio doesn't turn on. One time, it took 30mins for the radio to finally play music...
Old May 8, 2009 | 11:56 PM
Mr B's Avatar
Ok, while driving, I moved my driver's side mirror and the radio turned off and the anti-theft light was blinking like it does when the car is off. Is this the relays behind the radio?
Old May 9, 2009 | 09:14 PM
revhi's Avatar
Agreed, its the relay, same thing happened to mine when I first got it. Seems to be a my05 thing. The relay is under the dash above where your right leg is. Theres 2 of them that look the same. I think its the one closer to the firewall. I had a detailed post about this a while back, but cant seem to find it.
gotOaks
Mar 17, 2012 10:50 AM
jbird0007
Jun 21, 2011 08:43 AM
mhdelano
Feb 21, 2010 05:59 AM
GJ02SPJ
Aug 27, 2007 08:59 AM
gbuka
Apr 27, 2005 10:45 AM
