Strange/Crazy Radio Problem
Old Feb 19, 2010 | 03:08 PM
mhdelano's Avatar
Default Strange/Crazy Radio Problem
Symptoms:
1.) Sometimes takes up to 10 minutes for the radio to turn on, after the car is started and I'm driving around. The only thing I can do in the meantime is eject cd's.
2.) When I plug something into the accessory socket, the radio turns off. When I unplug the accessory it turns back on.
3.) Possible related, sometimes the accessory port does not give my accessory (gps usually) any power.
The accessory port is pretty loose, I can jiggle it around, not sure if that has anything to do with what is going on. Also the radio is stock.
Any ideas??? I know people say to check the accessory fuse, which i have and it is fine. Wouldn't an intermittent problem not be related to a fuse anyways?
Thanks
Old Feb 20, 2010 | 01:34 PM
Ottercycle's Avatar
ya, fuse would not be intermittent...unless there was a poor connection in that area that was succeptible to vibration/movement. but that would not be the fuse itself and you would likely have intermittent power loss.
sounds like an internal problem within the radio, though you could check your ground connection just to eliminate that as a cause.
Old Feb 20, 2010 | 03:05 PM
revhi's Avatar
Radio relay, do a s2ki search on it
Old Feb 20, 2010 | 04:28 PM
DFWs2k's Avatar
^ i agree, radio relay, and think that the accessory/12v outlet is a separate problem, those have been known to come loose/need replacement
Old Feb 21, 2010 | 05:59 AM
mhdelano's Avatar
Thank you so much, this has been annoying the hell out of me for a while!
jbird0007
Jun 21, 2011 08:43 AM
Gator_S2K
Apr 6, 2011 10:26 AM
PokS2k
Jan 29, 2011 02:11 PM
Antonio'S2K
Aug 25, 2010 03:37 AM
gbuka
Apr 27, 2005 10:45 AM
