Window question
Old Jul 6, 2002 | 03:59 PM
mschloss's Avatar
Default Window question
Have had no problems with my MY02 with about 6,000 mi now. However, I recently noticed that the drivers side window does not go down all the way when lowering the top. I am sure it used to... Anyone else ever had this problem?
Old Jul 6, 2002 | 04:48 PM
PokS2k's Avatar
yes this is a common problem. The dealer should fix it.
Old Jul 6, 2002 | 05:48 PM
Dallas's Avatar
It is indeed a common problem. You will notice that the auto-down function does not work properly, either. The motor/regulator needs to be replaced. I've had to have mine done twice now.
Old Jul 6, 2002 | 08:15 PM
eimea's Avatar
mschloss,
There is a Technical Service Bulletin from American Honda out for that problem. Your local Honda dealership can fix it.
Old Jul 7, 2002 | 05:20 AM
mschloss's Avatar
Thanks Guys!
Old Jul 7, 2002 | 05:30 AM
21wS2K's Avatar
MY01 is in the shop now in fact getting the auto down motor replaced.
--Jim
Old Jul 7, 2002 | 09:04 AM
Stratocaster's Avatar
MY02 is waiting on the parts to vhave this done as well.
Old Jul 7, 2002 | 10:46 AM
Screamin'JD's Avatar
My '02 did the same thing about a month after I got it. Before I got around to taking it in, it fixed itself! I have since noted that some others on this board have also experienced this "self-healing."
So, you might want to give it a few days before you take it in.
Old Jul 7, 2002 | 11:08 AM
boiler's Avatar
[QUOTE]Originally posted by Screamin'JD
[B]My '02 did the same thing about a month after I got it.
Old Jul 7, 2002 | 11:27 AM
bguernsey's Avatar
Ugh, you know- there was a lot I needed to get fixed before my warranty ran out. I also meant to renew it... I doubt the dealer will do the TSB for me now that its past warranty.
-B
