DIN Pocket for Factory Radio?
Old Jun 15, 2009 | 06:00 PM
S2K Kart's Avatar
Default DIN Pocket for Factory Radio?
Just curious... For you guys that have cut your dash for a Navi/Radio, what did you replace the factory radio with?
Anyone have a good suggestion for a nice replacement pocket (more storage is always good). I know I've seen some trick Boost Controller and EDFC installs, but I'm looking for something more stock-ish. =)
TIA
Old Jun 17, 2009 | 08:19 AM
S2K Kart's Avatar
Come on... I know you guys aren't just leaving your factory radio in there.
Old Jun 17, 2009 | 03:23 PM
GTS Jeff's Avatar
Google "DIN pocket"
Old Jun 17, 2009 | 06:42 PM
Stealth_SUX_'s Avatar
a univeral pocket will work, u may have to make your own screw wholes but thats easy..
Old Jun 17, 2009 | 08:06 PM
GrandMasterKhan's Avatar
i have A/F wideband, Amp temp, and Boost gauges mounted there.
Old Jun 18, 2009 | 05:45 PM
S2K Kart's Avatar
Yeah.. I had ordered the Universal Pocket from Crutchfield... Comes with a couple different mounting brackets and different size trim pieces for the front.
I just don't wanna find out after I'm done 'making' it fit that there's a OEM-ish option out there that would look 100x better and install 100x easier.
-M
Old Jun 18, 2009 | 07:59 PM
The universal din pockets by metra will have clip in brackets on the side which should allow the pocket to clip right into the own din hole. They also come with a bunch of trim rings which will fill any gaps.
I wonder what the cr has in that space.
Old Jun 19, 2009 | 12:00 PM
speedworksracing's Avatar
The door is screwed closed on the CR that does not have the optional radio and A/C
Old Jun 22, 2009 | 12:48 PM
S2K Kart's Avatar
Oh, that sucks.
I didn't even think about what the CR had... too bad the answer is... Nothing! =)
I will report back on the universal pocket. Should end up working fine.
-M
mr_internet83
Sep 27, 2013 06:37 PM
elude
Dec 15, 2005 09:45 AM
Darien1629
Mar 22, 2005 04:13 PM
S2K'ing-IN-Spokane
Jan 12, 2005 06:36 AM
ralper
Nov 22, 2003 07:47 PM
