MAP Sensor Story
Old Aug 18, 2002 | 06:13 PM
tom717's Avatar
Default MAP Sensor Story
Story - Going in to get spark plugs recall this past Thursday and the S got a hairball (bad fuel first thought) then stalled at stop sign. Then could not accelerate hard without hesitation so have to stay at low rpm's - get to dealer - spark plugs replaced - problem still there - I (based on this board) suggest they check MAP sensor - they are puzzled because of no code - the dealer's S expert continues work on the S the next day (when he was to be on vacation -special thanks) - finally they force a code.
Dealer says they had to "take pictures" when they test drove it with something attached to engine (and then send info back to Honda tech specialist) - result Honda tech says MAP Sensor needs to be replaced (under warranty). Done - works fine - including hard day yesterday testing the super fine twisty 9/22 Maryland - PA Border Run Route (to which you are invited): https://www.s2ki.com/forums/showthread.php?...&threadid=73891
When the S was picked up the dealer says "Where did you get that technical information (on the MAP sensor)"-- I told him this Board gets a gold star (including the search function). Thanks.
Tom
Old Aug 18, 2002 | 07:28 PM
S TWO K's Avatar
I've had this replaced once already, probably a second time tomorrow.
Old Aug 18, 2002 | 09:57 PM
The Unabageler's Avatar
I tried replacing it once but the replacement failed too. What works best for me when that happens is some medium strength percussive maintenance on the sensor and then things are hunky dory once I restart the car.
Old Aug 19, 2002 | 05:57 AM
tom717's Avatar
Anybody know that they would have put on my engine "to take pictures" while they test drove it?
Old Aug 19, 2002 | 06:49 AM
Sideways's Avatar
Maybe the OBD II scanner or other diagnostic electronics looking at current outputs.
G375 DAN
Oct 2, 2015 12:49 AM
I_s2k1
Jun 9, 2013 04:49 PM
Arian
Jun 7, 2012 11:57 PM
albe
Apr 22, 2008 01:19 PM
eddie623
Aug 13, 2002 02:06 PM
