AP1 map sensor replacement
My car has been running very rich for some time now, with the occasional bog down / hesitation when moving off from a stop - especially in warm weather. After a set of brand new spark plugs , upper engine clean-up, map whack and mechanic diagnosis I believe that the MAP sensor may need replacing.
I’ve rung Honda asking about the MAP sensor replacement – however they do not sell the MAP sensor on its own – they are asking me to buy a brand new intake from them for $750.
Has anyone here had to replace their MAP sensor? I am interested to hear your experiences with aftermarket ones and any issues with mating it to the stock MAP socket. Any other troubleshooting steps to perform before buying a new MAP. CEL codes checked out clean…
Thanks,
Arian
Thanks,
Arian
Spray the wiring plug with contact cleaner and push it on/off many times. Often the MAP sensor is fine, just the contacts to it that are playing up.
Sometimes cable tying the wires so they pull to the side skews the contacts in the connector enough to ensure good contact.
Yup, try Chris' therapy first. Failing that, buy online from a Honda parts distributor.
Keep in mind you'll probably have to go OEM. The third party ones will mostly be other ranges for forced induction.
Originally Posted by aj_shortman' timestamp='1337520232' post='21713905
dont we run rich from stock? how many lm per tank u gettin?
You can def get a MAP sensor by itself. Its the TPS sensor that is not sold seperate and needs a new throttle body. Seems strange that Honda Au tried to make u get a new TB.
