Wastegate on my CTSC?
Old Jun 5, 2010 | 08:20 AM
SeanSerino's Avatar
Default Wastegate on my CTSC?
So I purchased a CTSC used from the forum. It came with what I thought was a blow off valve (I'm a noob at F/I.) I was looking at other BOV/CTSC set ups, and I was realizing that mine is different. So, it turns out I have a Turbonetics Wastegate on my aftercooler (http://www.phantasmusa.com/t10101.html this same one) p/n 10101. Is this helping me at all? The bypass valve is still hooked up to the intake.
Pictures below. Is this doing anything for me? Should I disconnect/cap the hose on the left side of the AC going to the bypass valve/intake?
Old Jun 5, 2010 | 09:27 AM
NaturalAspirations's Avatar
WTF!!!!???
Old Jun 5, 2010 | 10:11 AM
SeanSerino's Avatar
I know right
Old Jun 5, 2010 | 10:25 AM
deathsled's Avatar
Ok so this is actually functional. Some of the big time SC guys (not s2kiers, lol) will use a wastegate on the intercooler piping to regulate boost just as you would use one on the exhaust manifold in a conventional turbo setup.
The idea here is since you have that wastegate you can now run the smallest SC pulley possible to get the most out of the supercharger. If you fuel system can't handle 12-13psi at redline or anything above 7psi anywhere then the wastegate allows you to bleed off the excess boost to keep things manageable. You can now have the ramp up of the smallest pulley and pick up that low/mid range power without having to be able to support the highest boost and high rpm.
If you ever wanted to run a boost controller on a centrifugal SC this is how
Is yours actually hooked up to anything? Direct vacuum line to engine or a boost controller? It's entirely possibly you've already got a 3.0 pulley or something and the wastegate is capping your boost to 7-8psi. Some boost vs rpm data from your car would tell us a lot.
Old Jun 5, 2010 | 01:20 PM
SeanSerino's Avatar
Interesting.
I bought the kit used and the wastegate was already mounted to the aftercooler. I do have a boost gauge, and I think the boost gauge is hooked up to this (possibly, I saw a hose running from the wastegate, later on I'll try to trace the end and see where it's going.)
I know I'm currently running a 4.25" pulley, but swapping on a 4.0" this weekend. Later this summer, I'll do high boost/tune/ems/injectors/etc.
Old Jun 5, 2010 | 05:21 PM
deathsled's Avatar
Have you asked the previous owner anything about the kit? It would be interesting to know what spring was in the wastegate. If it was something like 7-8psi or even less then you could possibly upgrade to a 3.0 pulley without needing ems or injectors and enjoy some midrange gruntt.
It would be great to hear how the previous owner was utilizing it.
Old Jun 5, 2010 | 08:05 PM
s2k aok's Avatar
interesting part to incorporate, i wanted to do up a custom setup before using this and run a full rpm really low boost setup, just tuning with a rising-rate fpr...
Old Jun 6, 2010 | 04:33 AM
SRap1's Avatar
thats awesome ive been wanting to find a way to get more low-end out of the centrifugal, i think i will try this....
Old Jun 6, 2010 | 05:03 AM
RAIN H8R's Avatar
wow, that is interesting.
Old Jun 6, 2010 | 09:30 AM
dsddcd's Avatar
This is correct but I have yet to see a system with this that actually works. In theory the CFM and pressure should allow to dump the excess charge but among other things the modulation was difficult. The other issues is excess heat, by over compressing the charge you create extra heat which lowers the efficiency. That being said if it does work then I will gladly take the reduced top end to gain low end.
Bottom line it is there so give it a shot.
Here is some info you may want to read.
https://www.s2ki.com/forums/index.ph...pic=299606&hl=
