Wastegate on my CTSC?
Old Jun 6, 2010 | 10:15 AM
Sportster's Avatar
why would you use a SC instead of a Turbo?! If you dont want top end power and ur interested in low-mid, then just get a small turbo! there is no reason in spinning a SC to its limit to get more low-mid power and dump the 'excess' boost! Its just not efficient!
On the otherhand, you can upgrade to a 2.4 NA and almost get the same low-mid end power.
Old Jun 6, 2010 | 11:10 AM
deathsled's Avatar
For the same reason people choose to go SC in the first place? Ease of installation? Reliability?
Old Jun 6, 2010 | 01:43 PM
RAIN H8R's Avatar
Bingo!
Old Jun 6, 2010 | 01:53 PM
DeadZero's Avatar
Originally Posted by NaturalAspirations,Jun 5 2010, 09:27 AM
WTF!!!!???
Old Jun 6, 2010 | 02:14 PM
Sportster's Avatar
I am SC myself for the same reasons, ease of installation, reliability, low temps etc.
But if I wanted low-mid range, and boost up to 10psi, I wouldnt go with a SC and a wastegate and spining the SC to its limits just to get boost on the low RPM side, I would go with a small turbo. There are many bolt on turbo kits out there that are as easy installed as a SC and especially for low end power a lot more efficient than a SC.
Maybe its just me, what can I say...
Old Jun 6, 2010 | 04:33 PM
SeanSerino's Avatar
Next weekend I'm going to see about removing the wastegate and either blocking the hole for it, or seeing if I can find a BOV which can fit over the same hole.
Old Jun 6, 2010 | 04:52 PM
camuman's Avatar
why, you should test this out. in theory it should work. id love to see a dyno of this with the 3.0 pulley but limited to 10psi.
Old Jun 6, 2010 | 05:05 PM
SeanSerino's Avatar
I don't know if the wastegate is even functioning, and at what psi it's set at (if it uses a spring), and I don't want to get a boost controller, etc.
Old Jun 6, 2010 | 09:12 PM
SRap1's Avatar
then just leave it there.... the spring inside will keep it shut, but i think you should really test it out
Old Jun 7, 2010 | 06:10 AM
sparrow's Avatar
yea man try it out
