Man, what a project. It turned out pretty well. After all that has been posted about audio upgrades I have to say for the time and money I would not do it again - on a convertible anyway. I would stick with the upgraded front speakers (components), definitely rear speakers and head unit if you are still looking for more power and amp all speakers. I have the 60x4 Alpine 7894 but it gets distorted when you try to really drive the sub in the trunk. I guess an Alpine 4-channel amp with new wiring may be the last and final upgrade to the audio. See my sig for currently installed components. Here are some pics.
I made a small 1/4" frame then glued the fiberglass mat on to it and let it fall into the well.
Applied resin
In the Florida heat it set in about 20 minutes
Topped with 3/4" MDF and auto carpet - covered the bottom with felt so it would not snag when removing
Final product. Waiting for the Polk MOMO grill cover to protect.
Not bad for a first time project!
Nice work, i m surprised your not happy with it. I have a similar set up that i did in my trunk but i used a ported box instead.
I would suggest maybe trying a small 2 channel just to run your sub. I m using two 2 channel amps to run my set up, but i dont have rear speakers either. I cant even begin to tell you how happy i am with my set up. I feel thumping bass at 70 MPH with the top down!!! All from one ported 10.
Originally posted by 1a-race Looks real nice tampa. Did you find that mounting spot for the fuse you asked about? would you like to make another one? I'll trade your for one of these. https://www.s2ki.com/forums/showthread.php?...&threadid=80249
Fiberglass, my specialty. 9'x9' cloth sheet $10 on ebay. fiberglass resin $16 a quart. Its really easy to work with. Just apply fiberglass first to the project and then apply resin, my mom now has a fiberglass picnic table because I assumed you wet it with resin and then pick it up and place it where you want it.
Found the mounting spot - perfect - Thanks!. As for making another, not any time soon.
