Bought an '06 S2000
Originally Posted by HvRRZ,Nov 20 2005, 09:17 PM
pics of center console please
or atleast let me know if the peices are still silver. i believe i saw a pic of an 06 where it was black. if so then I'm ganna swap mine.
.or atleast let me know if the peices are still silver. i believe i saw a pic of an 06 where it was black. if so then I'm ganna swap mine.
Originally Posted by Nimbus,Nov 20 2005, 11:22 PM
center console piece is black on the '06. only the radio door is left silver.
time for a swap then. hmmm should i go buy from dealer or wait to trade with an 06 owner hmm..
Originally Posted by '05 S2K SBM,Nov 21 2005, 01:01 PM
Thanks for the linky. Regarding disabling the clutch, I was referring to some clutch sensor that people are disabling. I don't know exactly what it is called, obviously, but apparently it resolves an issue with the clutch and hard launches.
https://www.s2ki.com/forums/index.php?showtopic=275175
Yes, I agree with Ken. However, what I don't know is whether or not the clutch delay valve is "tuned" to work with the drive-by-wire throttle that's new in the MY06 car. It might be worth driving the car for a while before you decide you want to make this mod.
I'll just state for the record here that hard launches via clutch drops is not the intended use of the S2000 driveline. Most dealers will put this in the category of "abuse" if you end up returning for warrantee repair due to failure from this kind of treatment. You will likely risk damage to your differential as well as your clutch and tranny if you launch the car enough.
