clutch issues
Old Dec 20, 2005 | 08:00 AM
sks0170's Avatar
Default clutch issues
Fellow s2000 aficionados:
I am currently leasing an'03 s2000, which I picked up new. I have a little over 50k mi. on it. I have been driving cars with manual transmissions for over 21 years. My last car was a del sol and the clutch did not warrant replacement until after over 110,000 mi. The clutch on my car prior to the del sol lasted up to around 90,000 mi.
I have begun to experience issues with the transmission; i.e, I have trouble putting my s2000 in gear. It gets easier as the car warms up. But, it is not at all like when the clutch used to spring and the car could be put in gear easily.
Any information regarding this issue would be welcome and appreciated.
Old Dec 20, 2005 | 09:35 AM
raymo19's Avatar
Replacing the transmission dope is usually a good place to start.
Old Dec 20, 2005 | 09:55 AM
sks0170's Avatar
raymo19:
Do you mean replace the transmission fluid and the clutch fluid?
Thanks for the advice.
Old Dec 20, 2005 | 10:08 AM
raymo19's Avatar
Originally Posted by sks0170,Dec 20 2005, 02:55 PM
raymo19:
If you've changed neither for 30K+ miles, then definitely. And the diff fluid as well. The problem you described (gear engagement) could be fluid related or you may indeed have a clutch problem. I would replace the fluids and then see if it improves.
Old Dec 20, 2005 | 12:39 PM
sks0170's Avatar
raymo19:
Thanks for the advice. I did notice that the clutch fluid level is at the minimum mark. So, I will add dot 3 brake fluid and see if there is any improvement. I am trusting that is all that will be required to fix the problem.
Old Dec 20, 2005 | 12:53 PM
raymo19's Avatar
If you haven't and don't plan to change the other fluids as well, SOON, then I hope your lease is up in the very near future.
I would advise checking the manual for the 30K service. Many of the folks on this site who know best would advise transmission and diff fluid changes either annually or bi-annually.
s2000maniac
May 30, 2012 02:13 PM
mk84
Dec 17, 2007 05:53 PM
chrisn
May 28, 2007 07:32 AM
GpLhenS2000
Apr 9, 2005 03:42 PM
dundonr
Sep 2, 2003 09:41 AM
