Clutch Problem?
Old Dec 15, 2007 | 07:53 AM
mk84's Avatar
Default Clutch Problem?
Ok im new to manual driving and s2kz, I think ive F**Ck** my clutch but im not %100 sure, the symtoms are so on...Started the car, but wont go into gear, the clutch feel as though theres no clutch, then i put some clutch fluid in improved it a little and was able to drive home but the clutch was still very light...its as though i have 10cm of clutch to change gear...just wanted to know if the clutch is gone or its on its way out.any input will be be great
Thanks
Old Dec 15, 2007 | 11:33 AM
IntenseImports's Avatar
are you leaking any fluid? Could be your master or slave cylinder!
Old Dec 15, 2007 | 11:39 AM
RED MX5's Avatar
Thanks
If the clutch fluid was very low, you may need to bleed the system.
Check for leaks first. IntenseImports is correct; It could be your master or slave cylinder (or both).
Mostly likely not the clutch itself going bad. Just some problem in the hydrolics.
Old Dec 15, 2007 | 09:46 PM
mk84's Avatar
Not going into gear again, it does when engine is off but soon as i start it, it locks up, Doesnt seem to be leaking anywhere, is there any other way to know if its the master cylinder without taking it to a mechanic?
Old Dec 17, 2007 | 05:53 PM
mk84's Avatar
Ok so I took the car into the mechanic, he tightened some bolt or nut under the steering wheel and the car is fine, but the clutch feels different, before i used to push the clutch all the way down then soon as i let it go a little that was the friction point but now i have to release it almost to the top to get it moving....is this how its supposed to be?
Jag528
Dec 4, 2012 08:13 AM
deanbayley
Apr 4, 2012 09:54 AM
realmike15
May 4, 2011 09:10 AM
rikhemi
Sep 10, 2007 06:29 PM
ajkewler
Jan 9, 2006 11:36 AM
