Decisions, decisions
Thanks for the information. Lets see what happens. Id do a couple things to it but nothing mayor if everything is as supposed as to further inspection after and if Im able to buy it. Ill try and upload a couple pictures.
Both quarters have the rubber fender lip so not rolled nor pulled either
Also, want to ask you guys. The 04 has an M Factory 4.57 gear and with the install came all new everything on the differential. New seals and stuff. Is it good enough for a daily? I mean, I dont care for the whinning but my main concern is that I do regular freeway drives, 2 or 3 times monthly, 65-70mph for as long as 2 hours each way, everytime and I know the revs go up with the higher gear. That would put a lot of stress on the engine and drivetrain. Is it good enough to daily a car like that? Is M Factory reliable enough for that situation?
Update:
Want to say thank you to those of you that helped. Got my car last week. Went with the 03 SSM and it feels great. Couple things that need to be addressed though.
First, Im having a rev hang for some reason. Revs work where they should but as soon as Im comming to a stop and I press the clutch, it stays at around 2k and then drop after a second. Cant figure that out. Also, since it has an HKS cat back, the previous owner who got the exhaust, installed a test pipe so the secondary O2 sensor is throwing me a CEL. And, remember those bearings that were bad? Well, it isnt the bearings. Im having vibrations from my diff. Changed the oil and it was clean, as in no metal shavings or anything, but it is buzzing when in gear. Probably will try to get another AP1 diff and change it as a whole.
Any input would be greatly apreciated.
anorexicpoodle
Aug 22, 2016 11:07 AM
02_s2k
Apr 22, 2013 03:48 AM
