tips on searching for a used 2000?
Old Aug 4, 2006 | 05:48 PM
slover's Avatar
Default tips on searching for a used 2000?
does anyone know of things to watch for on the 2000 and 2001 models? or does any know what to look for in buying a used s2000? i need all the help i can get
Old Aug 4, 2006 | 06:16 PM
TheCarGuy2021's Avatar
Service records and carfax if available. Also, what I did to make sure mine wasn't beaten on too hard is check to see if it still has the original brake pads and clutch, should give you a hint to how hard it was driven. Check all the VINs on the body parts to make sure they match. The list goes on and on...
Old Aug 4, 2006 | 08:18 PM
METATRON's Avatar
CLUTCH BUZZ when decelerating.
Old Aug 4, 2006 | 08:24 PM
Eluded's Avatar
trashed engines.
Old Aug 8, 2006 | 09:38 AM
Ks320's Avatar
Also you should make should the car shifts properly. I've seen a lot 00-02s that have really messed up trannies due to abuse and the infamous 2nd gear grind ...
Old Aug 8, 2006 | 08:08 PM
Chazmo's Avatar
Take a look in the introductions FAQ link thread. That may lead you to some useful info.
Good luck!
Old Aug 11, 2006 | 12:45 PM
Ks320's Avatar
Also, check for holes and/or major wears on the soft top. Soft top's pretty expensive to replace. (not to mention you don't want a leaky roof when it's pouring outside)
guy13
Oct 30, 2013 01:27 PM
justind
Dec 12, 2010 08:46 PM
phatjoe
Apr 15, 2009 05:25 PM
zeabre
Oct 26, 2006 05:57 AM
potfish
Mar 14, 2002 08:46 AM
