Alignment Fundamentals
Good update
The way I understand it right now, caster is limited the lower you go ... there was a thread by a circuit racer in Dubai or somewhere that max'd out his caster at 6 degrees, and wanted to go down to like 8 or 10, he had to get an SPC Ball Joint to get it to work.
Whenever I get my car set up right to install the TC Design rear control arms, I'll take some pics so people can see what you're talking about w/ suspension angle on the rear.
Originally Posted by zbrewha863,Sep 8 2008, 04:23 PM
The way I understand it right now, caster is limited the lower you go ... there was a thread by a circuit racer in Dubai or somewhere that max'd out his camber at 6 degrees, and wanted to go down to like 8 or 10, he had to get an SPC Ball Joint to get it to work.
I Have noticed that it is easier to reach higher amounts of caster on the non-lowered S2000's than it is on the lowered ones.
(You switched from caster to camber in the post its slightly confusing? did you do this on purpose?)
Originally Posted by SLO S2k,Sep 10 2008, 07:28 AM
I need to bring the Fit in to get it redone.....I had it done there before yo u were employed by Honda.
Scot
Sep 2, 2004 07:17 PM
