Jacksonville 1st Coast S2000 Owners
HELP NEEDED
Old Jan 2, 2013 | 08:22 AM
That Guy 1987's Avatar
Default HELP NEEDED
What's going on guys? I was wondering if anyone with some mechanical skills could look at my clutch. Got in the car today and there is just to much play with my pedal. It disengages BUT I have to push it to the floor to do it each time I shift. Checked the fluid and was a little low so I added some but no difference.
Elliott
Old Jan 2, 2013 | 10:03 AM
axhandler's Avatar
How many miles do you have on it?
Any strange noises or vibrations happening?
Old Jan 2, 2013 | 10:37 AM
D_Spec's Avatar
Mine did this 2 weeks ago. I was basically empty. I filled it up. The next day it was back to normal. If it don't come back it might need to be bled. Make sure you have no fluid inside the car where the clutch pedal is
Old Jan 2, 2013 | 01:05 PM
^^^^ same, added some fluid and it must of been an air bubble in the line.
Old Jan 2, 2013 | 01:36 PM
AE_Racer's Avatar
Yea as derek said check inside the car under the clutch pedal and see if there's any fluid.. If not jack the car up on the drivers side and check your slave cylinder and see if its leaking anywhere.
Old Jan 2, 2013 | 03:05 PM
Yea fluid is still full and didn't see a leak. Going to check it tomorrow but I don't have never as much play but not the same though.
Old Jan 3, 2013 | 02:56 AM
gettin it's Avatar
Is this a new clutch? Have you adjusted the clutch pedal?
HighwayStar
Aug 15, 2013 03:31 PM
wickwirew
Jun 14, 2012 04:43 PM
s2krdstr
May 10, 2010 01:14 PM
ahrmike
Sep 11, 2008 12:03 AM
03S2kStud
Jan 12, 2007 04:56 PM
