Overheating and need some advice
Over view:
Car started running hot so popped the hood and noticed my top radiator hose was swelling and lower one was cold.
Bought a Honda thermostat and changed it out and it's still doing the same.
I'm leaning towards air in the system since I changed out my radiator but I did that over a month ago and never had an issue till two days ago.
Chime in if anyone has had this issue.
You may have a minor leak that is allowing pressure to escape. This will cause circulation problems, which shows the same symptoms of a bad thermostat (upper hose hot and swollen, lower hose cold and not as pressurized).
Have you tried Billman's coolant bleed procedure?
https://www.s2ki.com/s2000/topic/106...coolant-bleed/
KaNgArOo
Nov 24, 2014 12:23 PM
