Jacksonville 1st Coast S2000 Owners
Overheating and need some advice
Old Oct 12, 2014 | 09:27 AM
GaFilka Fish S2K's Avatar
Default Overheating and need some advice
Over view:
Car started running hot so popped the hood and noticed my top radiator hose was swelling and lower one was cold.
Bought a Honda thermostat and changed it out and it's still doing the same.
I'm leaning towards air in the system since I changed out my radiator but I did that over a month ago and never had an issue till two days ago.
Chime in if anyone has had this issue.
Old Oct 12, 2014 | 04:02 PM
AE_Racer's Avatar
Could be air. These things are a pita to get completely air free.
Old Oct 13, 2014 | 07:47 AM
dc2-2-ap1's Avatar
Rebleed the system and see if it continues.
Old Oct 13, 2014 | 07:50 AM
dc2-2-ap1's Avatar
You may have a minor leak that is allowing pressure to escape. This will cause circulation problems, which shows the same symptoms of a bad thermostat (upper hose hot and swollen, lower hose cold and not as pressurized).
Old Oct 13, 2014 | 12:16 PM
ado's Avatar
ado
Have you tried Billman's coolant bleed procedure?
https://www.s2ki.com/s2000/topic/106...coolant-bleed/
Old Oct 13, 2014 | 08:09 PM
So it is leaking from the thermostat housing. I've tried to seat this thing 3 times. Gonna give it another go tomorrow
Old Oct 15, 2014 | 07:46 PM
Sweet! 3rd gasket was the charm!
Old Oct 16, 2014 | 11:53 AM
Ryuu's Avatar
sweet... so, are you back up and running now..
Old Oct 17, 2014 | 07:03 PM
Yes sir. This car is a PITA to bleed the air out though.
Travisap1
Oct 8, 2016 01:39 PM
Omar46
Feb 26, 2015 08:27 AM
KaNgArOo
Nov 24, 2014 12:23 PM
Allday
Jan 8, 2014 03:23 PM
akimoto
Sep 28, 2008 10:18 PM
