asm harness bar?
Old Jan 8, 2007 | 06:57 PM
i</3speedbumps.'s Avatar
Default asm harness bar?
where can i find this?!
Old Jan 8, 2007 | 07:35 PM
HONDAP1's Avatar
anyone have a picture of this installed in the car?
Old Jan 8, 2007 | 11:03 PM
Nimbus's Avatar
Old Jan 8, 2007 | 11:32 PM
c17r15's Avatar
it won't work unless you're buying it for your passenger side. ASM doesn't make one that would fit the North American s2000s, that's why no one has it, costing $500 doesn't help either.
The bar is also NOT functional, ASM's site says it's for looks only.
Old Jan 8, 2007 | 11:55 PM
trivium's Avatar
Banned
Want to provide that info? I couldnt find that.
Old Jan 9, 2007 | 01:20 AM
c17r15's Avatar
http://www.autobacs-asm.com/original/s2000/others.html
Old Jan 9, 2007 | 09:37 AM
it LOOKs like it might work. haha. well im plannin on fabbing a bar up like that so i can run a harness.
Old Jan 10, 2007 | 05:26 AM
MINES13's Avatar
That is EXTREMELY dangerous without a roll bar/cage of some quality. If you roll and the harness bar keeps you from being unable to tuck, you will likely be critically injured or killed. Harnesses should only be used in conjunction with the proper roll over protection.
Old Jan 10, 2007 | 06:17 AM
bjeong1381's Avatar
I was actually looking into these until I found out the price.
Old Jan 12, 2007 | 08:49 PM
circa86's Avatar
it's not that it isn't functional, they highly recommend using a 4 point cage along with this bar, but the bar could be used to install the bar at the proper point.
but basically if you are thinking about using a harness for how it looks just don't. if you are thinking about it because it will hold you in your seat much better, (which means you all ready have a good after market seat) then just consider using the stock seatbelt until you have some type of cage.
one thing I have seen though, what about using the harness with only one shoulder strap? they are doing that all the time in cars without cages with harnesses, or just using the stock belt.
4点ハーネスブラケット
(4point Harness Bracket) well.... (4point haanesu buraketsuto)
S2000に4点式シートベルトを装着する めのブラケット。シートベルトの角 を最大限適正な角度に固定して装着 することを可能としています。安全 の観点から、4点式以上のロールゲー ジの装着を推奨しますが、ファッシ ンとしてフルハーネスを装着したい ーザーさんに向けてご用意しました 。
