caliper clearance with the RGII
I am thinking of buying a set of Advan RGII.
Running on OEM AP2 tyres (215 F 7.5 / 245 R 8.5)
The available ooffsets are +45 Front and +50rear
Will i have any rubbing issues?? I havent lowered the car yet, but i will in the future (not more than 1 inch)
Will these offsets change the behaviour of the car? I know that having a smaller offset makes for the car "wider", but will it make the S inbalanced in any way?
Will this allow enough space for a BBK? (endless, Brembo, Amuse)
Thanks to all you that can help me out
With the 18x8.0 +45 Advan RG2 will clear Stoptech, Brembo, and Spoon calipers with no spacers. Endless maybe but not too sure, I am thinking at most a 3mm spacer with those.
If you go with the 17x7.5 +45 or 18x7.5 +45 you will need spacers and possibly extended studs.
Good luck.
Good luck.
