Cam Specs - VTEC vs. below VTEC
Old Oct 25, 2007 | 06:12 PM
stantaur's Avatar
Default Cam Specs - VTEC vs. below VTEC
Are there different cam lobes & profiles for VTEC vs. non-VTEC mode on the S2000 engine, or is VTEC just engaging a different set of higher-ratio rocker arms at a certain RPM?
Reason I ask, is that there is only one profile people discuss for 0.050" duration and lift on these cams. That leads me to think it's one set of lobes, and VTEC is simply a higher multiplication of the lobe (via a different rocker arm that engages at an ECU-set and oil-pressure approved RPM point).
If there were two different sets of lobes (one profile for under VTEC RPM range, one for in-VTEC RPM range), we'd see TWO different set of cam timing figures -- maybe 222 degrees @ 0.050" in standard mode and 230 degrees @ 0.050" lift. Figures for comparison are below. I'm giving some thought to keeping my AP1 intake and getting an AP2 exhaust cam for its extra lift which will help my Stage 3 Laskey head and GT3076R.
USDM F20C (S2000
Old Oct 26, 2007 | 12:19 PM
LostMotion's Avatar
Two lobes.
Those figures don't report the non-VTEC lobe since most people don't care.
Old Oct 26, 2007 | 12:33 PM
LostMotion's Avatar
I have an AP1 IN and an AP2 EX on an AP2. Unfortunetly, I don't have a back to back with only that as a delta. Honestly though the AP1 IN is real gainer compared to the AP2, the difference in the EX is so minimal as to be non-important.
Old Oct 28, 2007 | 08:56 AM
ShocK's Avatar
So do AP1's benefit from AP2's exhaust cams?
Old Oct 28, 2007 | 10:31 AM
LostMotion's Avatar
My opinion is no.
Old Oct 29, 2007 | 07:47 AM
Soul Coughing's Avatar
i am doing the same on my turbo build.. i will not have back to back info either though
Old Oct 29, 2007 | 04:13 PM
ChefJ's Avatar
Take the valve cover off and look at the cams and rockers its plain as day.
Old Oct 30, 2007 | 11:38 AM
INTJ's Avatar
Anyone have a dyno plot for the AP2 head with the API intake?
doddg
Apr 8, 2014 10:51 PM
stantaur
Oct 25, 2007 06:15 PM
Blackie
Feb 26, 2003 03:19 AM
jelliotlevy
Dec 6, 2002 05:03 PM
CFBH
May 1, 2002 08:28 PM
