CF wing install on CF trunk?
Old Jan 28, 2007 | 09:14 PM
UniqueS2k's Avatar
Thumbs up CF wing install on CF trunk?
I have a mugen ss CF wing and i have a dry carbon Asuka trunk. Are there certain ways that i should take the install process? I dont want the Dry carbon to crack, how can i make this work? Does any one know of a place or shop that i can get these 2 pieces put together really clean?
Thanks for you time and help, Alex
Old Jan 28, 2007 | 10:09 PM
WindchaserS2K's Avatar
U sure the azuka are dry carbon cause I don't think it is and the install is easy just do it yourself man
Old Jan 29, 2007 | 03:44 PM
milkbubble's Avatar
Use a tiny drill bit and work your way up in sizes until the desire fit is achieved. And measure twice or more before drilling! In addition.. Our OEM trunks have little dimples as reference points for the factory spoiler. I believe the Mugen spoiler shares the same mounting points. I doubt your carbon part has it of course but you can compare the 2 to get an idea about where to plot the mouting points.
Old Jan 29, 2007 | 08:49 PM
GT Motoring's Avatar
Former Sponsor
Right on. Also, use some masking tape near the area you intend to mount the wing. this will allow you to place the wing on the trunk and mark where to you need your holes, as well as prevent scratches if you happen to move the drill, or it catches and jerks etc. In addition, it will also help prevent any chipping of the top layer of carbon or clearcoat. same metheod applies if it is wet or dry carbon fiber.
Old Jan 29, 2007 | 09:23 PM
Use a unit bit to drill the hole
Old Jan 29, 2007 | 11:24 PM
UniqueS2k's Avatar
Thanks for your help guys
Old Jan 30, 2007 | 06:23 PM
leester01's Avatar
Your trunk is wet carbon and I would use a small pointed grinding stone bit instead of a metal drill bit to avoid cracking
Old Feb 8, 2007 | 10:04 PM
PDX S2000's Avatar
put some superglue on the area you're going to drill, also put some superglue around it after drilling, this will keep the weave from fraying.. use a very sharp clean drill bit....
Old Feb 8, 2007 | 10:29 PM
hustlervibes's Avatar
I've also heard carbon fiber likes to be drilled at high rpm, so make sure the bit is up to speed before starting to put any pressure. I've heard of cracks doing it otherwise.
ex1mars
Dec 22, 2006 06:09 AM
gusrock77
Socal Swap Meet
13
Aug 19, 2006 07:25 AM
Nick32
Mar 20, 2006 07:56 PM
batikan
Jan 25, 2006 06:19 PM
EriS2k
Jul 11, 2004 08:00 PM
