F24 Build
Originally Posted by Silver9k,Oct 29 2007, 03:26 PM
I get a lot of how much more power does it make? Too...but honeslty right now I don't know, I plan to go do a little dyno tuning on Wednesday and find out. But Honestly I don't expect to be over 230whp anymore. If I am, awesome, and can it be? Yes, I made 263whp on Autowave's tune, but it was so aggressive that the motor burned up in 3 days. I'm running it safe now, I just want reliable fun.
Originally Posted by iDomN8U,Oct 31 2007, 07:35 AM
define aggressive
Anyway, with the A/F down at 12.7-12.9 and 20 degrees of timing it made 251whp 188wtq on a dynapack that stock AP1's usually get 200.
kail007, I built a destroked k24 to a 2.2L 3 years ago using an AP2 crank. We were going for a long rod/stroke and high revs. The crank snout needed to be modified to accept the Kseries crank sprocket.
Have you checked the crank sprocket/chain alignment yet? You may want to measure both crank snouts before you get too far ahead.
Can't wait to see the results!
My crank pulley mounts fine but since the engine is on a stand, I haven't been able to check the alignment for the accessory belt. As far as the sprocket goes, that seems to be fine. When I installed the oil pump it lined up perfect, so I am assuming the timing chain will too but I will know for sure when I get my head back from the machine shop.
Originally Posted by jacksonjw81,Nov 16 2007, 08:16 PM
Want to see DYNO
