J's racing front and rear calipers
Old Aug 25, 2008 | 12:54 PM
David_T's Avatar
Default J's racing front and rear calipers
Just wanted to ask if the work emo cr kai F 17x8 +47 and R 17x9 +44 offset would fit the J's racing BBK? or would i have to add spacers or need a larger rim?
Old Aug 25, 2008 | 01:25 PM
Sinji's Avatar
more likely have to go with lower offsets. at least a +35 on the front so add a 10mm spacer.
on my fn01rc i had a +35 but i added a 3mm to clear. the rear im not sure...
paper thin clearance:
Old Aug 25, 2008 | 07:33 PM
rob.ok's Avatar
The rear caliper position is more or less unchanged from stock. No worries there.
More detailed info about the rears can be found here https://www.s2ki.com/forums/index.php?showt...&#entry13088749
I don't know about Works but generally you need at least a 40 offset or lower I doubt that a +47 will work with out spacers. However depending on spoke design / face other offsets will work. The real problem is what are you going to do with your fenders????
For more information about Cobalt replacement pads for J's Racing / Endless 6 piston calipers please click the link https://www.s2ki.com/forums/index.ph...f=107&t=624949
Old Aug 26, 2008 | 10:22 AM
David_T's Avatar
ohh dammm ..don't really wana use spacers or anything..how about spoon calipers?? or would i need spacers as well?
Old Aug 29, 2008 | 05:07 PM
zbrewha863's Avatar
It depends on the spoke design and everything, but I think for Spoon calipers you need a +59 offset to clear w/ Work Emotions.
There's a whole thread on it in teh wheels subforum.
Old Aug 31, 2008 | 08:47 PM
David_T's Avatar
yup there is alot there but they all give different answers lol..some say you need a +35 offset, some say you need a 6mm spacer, some say it won't fit and now i get a +59 offset..LOL i really dunno which one to listen to
im going crazy to try to find out the right answer
Old Sep 1, 2008 | 05:57 AM
DerrS2K's Avatar
Sorry but there is no way a +59 offset will clear spoon calipers.
The confirmed Spoon caliper fitment for Work Emotion CR Kai is 17x7 +42 offset w/ +6mm spacer. J's calipers are a lot larger. The offset needed depends on the spoke design of the wheel as stated above which is why there are so many different recommended offsets.
https://www.s2ki.com/forums/index.ph...ic=338881&st=0
Old Sep 1, 2008 | 09:32 AM
Brian_s2000's Avatar
work emotion forged 17x8.5 +59 to clear the spoon.
you might also clear with work emotion forged 17x7.5 +40 on spoon
Old Sep 1, 2008 | 01:53 PM
DerrS2K's Avatar
I stand corrected. Does that fit in the wheel well without a stretched tire? I assume you would run the same rim size in the front and rear?
Old Sep 1, 2008 | 03:30 PM
David_T's Avatar
Ok so it says Work Emotion CR Kai 17x7 +42 offset w/ +6mm spacer and if im correct i would need a 11mm spacer? since im at + 47
merckx racer
Dec 6, 2016 11:15 AM
ATNCHN
Aug 7, 2015 01:42 PM
H22toF20
Feb 1, 2013 04:15 PM
David_T
Aug 31, 2008 05:22 AM
frozty
Dec 25, 2005 10:18 PM
