j's vs spoon
Old Jan 26, 2006 | 07:19 AM
  #21
papa5murf's Avatar
Originally Posted by Silver9k,Jan 23 2006, 08:59 PM
Just go with a $400 Koyo...spending $2000 for a radiator is like purposely running your car into a wall...why?
there so many other things i could buy with that left over money...
Old Jan 26, 2006 | 08:20 AM
  #22
Ludedude's Avatar
Administrator
Originally Posted by bluesaint,Jan 24 2006, 05:51 PM
Also, with S pattern, there's less of a chance a bad encounter with rock will drain all ur fluids
Oh please explain this gem.
Old Jan 26, 2006 | 01:59 PM
  #23
bluesaint's Avatar
sure. look at the fluid flow compairson chart below.
if a 1 inch rock were to strike both the stock radiator and a turn flow type radiator, the "statistical" chance of the rock striking a leak in the downflow radiator is higher than the turn flow. That's all I'm saying.
Old Jan 26, 2006 | 04:31 PM
  #24
news2kroller's Avatar
how much do water temps drop with these JDM s pattern radiators over stock radiators.?? thanks.
Old Jan 26, 2006 | 07:46 PM
  #25
Silver9k's Avatar
Water temps wont drop. That is based on the thermostat, what the radiator does is keep the temperatures more constant when under high load and racing. The engine heats up a lot. But because the radiator can deliever MORE COOLER water it is able to more easily maintain the temperature
Old Jan 27, 2006 | 05:14 AM
  #26
quickysrt's Avatar
contacted j's last night and the radiators must be orderd from japan...
Old Jan 27, 2006 | 09:22 AM
  #27
AJ PwR's Avatar
Actaully Spoon is made by Tabata and their N1 model is equilvelant to the Tabata TR349 which S2fire is running on this board. The price for the TR349 cost a lot cheaper compare to Spoon N1.
If you need help for getting one, please PM me
Old Jan 27, 2006 | 12:38 PM
  #28
quickysrt's Avatar
i was the one that orderd the full cf typev hood yesterday. i would have gotten the radiator also but i need it sooner than the 1 month it takes to get from japan.
Old Jan 27, 2006 | 01:28 PM
  #29
bluesaint's Avatar
AJ-Racing should be able to have it air freight to you if J's has radiator in stock.
Old Jan 27, 2006 | 01:35 PM
  #30
HvRRZ's Avatar
i have a koyo i can sell you for $1000......
