Short in ECU? Please help
Old Nov 29, 2008 | 07:17 PM
UsmcSway's Avatar
Default Short in ECU? Please help
Well my car has been sputtering, and dying, and idling high and then low constantly and randomly shutting off on the highway. I took it to honda nad friggin 85 dollars later just to hook up to computer to check cel, it said torque sensing error, speed sensing error, and a few other problems. The mechanic said it could possibly be a short in one of my wires? Now the heat bars will drop 1 or 2 bars and then the car will shut off, or it wont let it rev above 4k and the car basically wont move, and I have to turn key off and then right back on. PLEASE HELP!!!!
Old Nov 29, 2008 | 08:51 PM
Mrfixit687's Avatar
What mods have u done to the car?
Old Dec 1, 2008 | 07:41 AM
UsmcSway's Avatar
supercharger was installed previously. We took it off made it NA. Then I was going to turbo so we took injectors/map sensor, and other parts for the swap off. We recently re soldered the injector clips/map sensor w harness. One of the o-rings on the top of my 3rd injector is chipped and is leaking fuel as well. But before even while supercharged it had the same problem. I always thought it was crappy gas cause gas has ethanol in some places back home.
Old Dec 1, 2008 | 09:00 AM
HiVolume's Avatar
I've had a similar issue with my AEM EMS. Adding a big ground between the ECU and the chassis helped things, but the problem was due to a missing ground between the engine and the chassis. You can easily use booster cables to ground your engine to the chassis (2 clamps on chassis, 2 other clamps on engine).
Try that out and let us know.
Old Dec 9, 2008 | 09:52 PM
nigaphan's Avatar
Did you splice into your ecu wires for your fuel managment or used a frogger?
Type S
Jul 5, 2016 10:09 AM
UsmcSway
Dec 1, 2008 10:36 PM
S2K Sideways
Jun 18, 2008 06:48 PM
turboelan
May 31, 2004 04:20 AM
evf2000
Nov 11, 2003 03:49 AM
