Takata harness backing plate, Location?
I've tried the search function, racing forum, and countless hours trying to find out where the backing plate goes to install my Takata harness. I even saved the pictures once, but my computer crashed and I didn't backup the file.
Any help please, I need the location where the harness eybolt and backing plate are to be installed on the tranny side of the S2000.
I basically know the general area, but there was one picture that showed the exact location to drill. I don't want to phuck up and drill like 3 holes in my tranny tunnel.
SDUECE I just drilled mine. The one side you have to be careful with is the passenger side. You have to drill it closer to the back of the car because there is a reenforcment plate on the passeger side in the tranny tunnel. You can see it when you jack up the car. I drilled the driver side about the same level as the original seabelt hole and about 1 and a half back from the inner rear seat bolt. I did this so I didn't have to interfere with the seat bolts. I did the same for the passeger side but a little farther back so I didn't hit the reenforcement. I used a lock nut with fender washers.
