harness
Old Apr 5, 2012 | 04:41 AM
yumad's Avatar
Default harness
so im looking to get a harness for my, before anyone says anything, i already have a roll cage HD and recaros SPG's, im looking at the Schroth clubman harness and looking to do the snap in and my question is more so to the eye bolts, they have 2; 38mm lenght or 22mm. im not quite sure i might need to use for the sub belt and also if i would need a reinforced plate for all 3 mounting points om the floorboard.
http://www.schrothracing.com/store/C...an/clubman-III
http://www.schrothracing.com/store/C...olts-eye-bolts
Old Apr 7, 2012 | 03:23 AM
Brian617's Avatar
Bump cause I'd also like to know the answer to this. I want to get the Schroth Profi II-6 but it only comes with 22mm long eye bolts and two backing plates. Does anyone know if these will be long enough to go through the floor pan and trans tunnel for the inboard lap belt? All will be used with a Schroth backing plate with welded nut.
Old Apr 7, 2012 | 09:06 AM
Brian617's Avatar
I called Schroth and the guy said the 22mm bolts are generally long enough to reach through the floor pan and trans tunnel, and that they rarely sell the 38mm eye bolts. Justin at Rockstar Garage also said the eye bolts that come with Schroth harnesses have been long enough in his S2K installs.
Old Apr 7, 2012 | 09:43 AM
robrob's Avatar
Yes, the 22mm bolts should work fine.
Inf case you haven't seen it here's the harness how-to on my website by Matt: http://robrobinette.com/S2000Harnesses.htm
Old Apr 7, 2012 | 09:50 AM
chuhsi's Avatar
whatever came with my profi II was perfect
Old Apr 7, 2012 | 10:13 AM
Brian617's Avatar
Thanks! I definitely refer to that page often. For the inside lap belt on the trans tunnel, did you drill a hole and use a backing plate, or did you tap it to screw the bolt in? I'm not sure how thick the metal is there.
Old Apr 7, 2012 | 08:09 PM
robrob's Avatar
You must drill and use a backing plate. The metal is way too thin to tap and wouldn't support a seat belt in any kind of bump.
seansniper
Apr 1, 2013 08:56 AM
krnmike
Dec 10, 2008 07:32 PM
Rusler Firbrand
Apr 13, 2006 08:58 PM
kubos2k
Mar 20, 2006 12:39 AM
