Temperature problem with gears?
Old May 3, 2006 | 01:29 PM
Headchef's Avatar
Active Streak: 30 Days
Default Temperature problem with gears?
Guy's I'm considering installing 4:57 gears in my car. Should i be concerned with overheating at all?
Old May 3, 2006 | 02:47 PM
xviper's Avatar
What exactly do you mean by this? And how would you tell? (I can tell on my car. Just wondering how you will be able to tell.) The fact that Honda made a casing with cooling fins on it, means that the designers wanted to have a way of dissipating some heat. I believe Spoon even makes an aftermarket casing where the fins are huge.
Old May 3, 2006 | 03:51 PM
Headchef's Avatar
Sorry-my post may be confusing. I meant would there be any problems with the engine overheating due to the 4:57 gear ratio?
Old May 3, 2006 | 04:04 PM
xviper's Avatar
No. Your engine rpm will be 11.5% higher at any given road speed in the same gear. For around town, you may simply find it more comfortable to drive in one higher gear than you normally would. For highway cruising, 11.5% would only represent approx. 500 rpm more (70 mph or so). This is quite inconsequential as far as the engine cooling system goes.
Old May 4, 2006 | 12:18 PM
Headchef's Avatar
Thanks Viper!
210[s2k]TX
Feb 28, 2010 01:05 PM
KarmaHunden
Jan 13, 2008 10:05 AM
rikhemi
Nov 2, 2006 10:47 AM
flaugh
Jun 11, 2004 02:41 PM
