TestPipe installed: Best next NA mod?
going the na route, i've installed a testpipe (70mm invidia) and running a K&N drop-in wo/airbox lid - what's the next best mod?
What the best order to install these mods?
Hondata header reflash
70mm single exit exhaust
header
cai
header
cai
Next best mod is free...put the airbox lid back on for a couple more ponies.
Hondata reflash would be worth it...but you should check to see if they offer the reflash for MY07 cars. Last I saw they were limited to just a few months of MY06 production. Something about a firmware change.
thanks guys
i have the lid off because i like the sound and it's winter - with lid off - is the lose from heat, flow or both?
hondata works w/ '07s as long as they match a certain range of ecu serial #'s
so single is best next mod along with hondata... Thanks
just like the other guys...I'd say gears although it's not on your list. I have some of the mods you listed that you wanted to get next, but gears will make the biggest difference and you wont regret it after you get it. I promise!
