TOP FUEL power chamber carbon intake
Old Oct 5, 2008 | 08:50 PM
Glenn6one9's Avatar
Default TOP FUEL power chamber carbon intake
about to pick up this intake......is it any good??? or should i stick with AEM V2 cold air???
Old Oct 5, 2008 | 09:01 PM
modMonkey's Avatar
If I recall correctly, it is basically and air horn and a filter enclosed in CF. The CF should reduce intake temps in theory. The air horn works the same as the air horns on ITBs.
Compared to the V2, you should get better throttle response. However, you can get the same effect with a gutted OEM air box.
Old Oct 5, 2008 | 10:06 PM
Glenn6one9's Avatar
sorry just got s2k, how do i gut the stock airbox?
Old Oct 20, 2008 | 12:09 AM
Snowmoto125's Avatar
cut the plastic divider to the left of your air filter.
Old Oct 20, 2008 | 11:01 AM
dparm's Avatar
The Top Fuel intake is going to choke you off at high-RPM. The flow velocity is way too high at higher engine speeds and you create turbulence at the TB opening.
S2kRob
Feb 27, 2012 09:07 AM
GT Motoring
Nov 30, 2011 09:21 AM
VeilSide AP1
South Florida
43
Feb 26, 2010 01:31 PM
RedheadRacing
Jan 10, 2007 06:20 PM
cvedral
Aug 30, 2006 06:00 PM
