Old Jul 18, 2008 | 08:23 AM
Rewind299's Avatar
Default ...
Old Jul 18, 2008 | 09:00 AM
lYellowDragonl's Avatar
a sub is all you need...
Old Jul 18, 2008 | 09:56 AM
magikcow's Avatar
buy my amp.
https://www.s2ki.com/forums/index.php?showtopic=606002
Also BTW a sub is not all that you need.
Old Jul 18, 2008 | 10:23 AM
magikcow's Avatar
get the alpine PDX amp I would not trust to throw a small amp especially sony under the seat.
I could imagine cabin fire. Or at least a lot of melting foam.
Old Jul 18, 2008 | 10:45 AM
magikcow's Avatar
Originally Posted by Rewind299,Jul 18 2008, 01:38 PM
Fire??? Why especially Sony and not Alpine?
The sony I have delt with before seem to be a little on the hot side. the new pdx alpine amps have a small foot print and run REALLY cool.
Old Jul 22, 2008 | 05:53 PM
scooter77's Avatar
I got mine done at circuit city
Old Jul 23, 2008 | 05:59 AM
WhrDLMI's Avatar
Have you found the Electronics Junkie forums yet??? There are lots of really good pics and some decent advice there, too.
https://www.s2ki.com/forums/index.php?showforum=26
I should also add that I agree with Cow... Under the seat is BAD. Not much room and it will get toasty there... If you are shorter then most, you could try behind the seat. I have seen that work successfully but, ultimately, in the trunk works best. Either where the spare tire is or in the tool well.
Good luck!
Old Jul 23, 2008 | 07:00 AM
WhrDLMI's Avatar
Originally Posted by Rewind299,Jul 23 2008, 10:21 AM
Yep, I've been reading up on the electronics section. I didn't want to use any trunk space but after looking under the seat, I agree that it doesn't look promising. Reading through the electronics section I found several amp installs that used little to no trunk space - I'm not opposed to the idea after seeing those.
If you can find a REALLY little amp (like a little MTX two-channel), it could be mounted inside the spare tire. Just put in on a round piece of MDF and bolt it in with the tire. Would be tight, but it might work.
If you don't want to give up trunk, adding a sub is going to be a PITA. There is a way to get it in the pass side foot well but that takes a TON of work and means you can only transport short passengers.
I have seen a couple of shots where owners have put a small sub in the secret compartment. I have never heard the installs, though. Again, I would imagine this to be a TON of fab work and, in my opinion, not worth the results.
I have my amps (one four channel and one two channel) in the spot where the spare should be. It was taken out a LONG time ago... I also have a 12" sub mounted in the tool well. This install works fine for me and my daily-driving needs. I just accept the risk with the lack of spare tire.
Old Jul 23, 2008 | 07:32 AM
WhrDLMI's Avatar
I usually just carry a can or two of fix a flat along with me on road trips. I know there is risk but I am willing to accept it.
That being said, I am willing to bet that you will be just fine with the aftermarket head unit and a good set of door speakers. I actually get quite a bit of bass out of mine. I just like to feel my music as much as I like to listen to it.
Good luck with it. Be sure to keep us posted.
RevRanger
Apr 11, 2016 02:07 AM
austx2k
Aug 24, 2007 01:20 AM
Enthralled
Jan 30, 2007 12:27 PM
CyrusA
Jun 28, 2004 10:30 AM
TampaS2k
Sep 16, 2002 03:51 AM
