AP1 Retainer upgrade with AP2 retainers
Old Nov 30, 2015 | 10:28 PM
357MAGNOLE's Avatar
Default AP1 Retainer upgrade with AP2 retainers
I recently purchased a 2000 AP1 with 122K on the odometer.
After extensive research I am wanting to do some basic maintenance stuff to insure a longer life of the engine, I came across the valve retainer issue from the AP1 models and went ahead and ordered 8 new AP2 retainers and 16 keepers.
I need to find a trusty, local shop that wont charge me an arm and a leg to do the replacement. I usually do most work on my vehicles myself, but being so new to the platform I really don't want to screw it up. Suggestions to a shop or a well known person with a great reputation would be appreciated.
Also, feel free to tell me the shops to avoid at all costs... Last thing I need is a non trustworthy mechanic screwing my car up and/or overcharging me.
Also I still cant receive or send PM's on here so my email is 357MAGNOLE@gmail.com if you dont want to air out stuff here.
Thanks
-Chris
Old Dec 1, 2015 | 04:41 AM
gfacter's Avatar
I recommend Ben Shaffer at Daisy Import, he did my retainers back in 2005. I have known Ben 25 years, the man knows Honda's.
http://www.daisyimportauto.com/
Old Dec 1, 2015 | 09:44 AM
357MAGNOLE's Avatar
Pulled the valve cover today to check it out, nothing overly concerning that I see. Some of the retainers look a little flatter in the photos but I think it was due to the camera (Iphone) and lighting and angles. I did not see anything concerning, all retainers looked the same, no cracks, no excessive wear. It would be great to find someone local that has done this a few times and wants to help a guy out, I would compensate for your time. I dont mind paying to have it done, but learning to do it myself is what I prefer.
Old Dec 1, 2015 | 09:54 AM
goldenfri's Avatar
He did mine long ago as well.
IIRC the cracks usually start underneath so they are very hard to see unless you know what you are looking for.
Old Dec 1, 2015 | 10:59 AM
gfacter's Avatar
I don't know many people that have done that work themselves, Ben said it was a PITA and I believe him.
I did change the valve springs on a Z06 vette a few years back, that was not so bad.
Old Dec 1, 2015 | 11:42 AM
e3opian's Avatar
You won't see the problem without tearing it down first.
OP, I replaced a broken valve spring on my wife's Cooper S a few years ago (without pulling the head.) It was not something I would do again if I could avoid it. If you have the means, take it to a pro. I have never used Daisy's but I will vouch for anyone that gfacter vouches for.
Old Dec 1, 2015 | 12:03 PM
357MAGNOLE's Avatar
I appreciate the input so far, from another thread I started asking for opinions I am beginning to think I did not over rev the motor as much as I originally thought.
I was cruising down the road with my kid, I went into 3rd before entering a corner and I came out of the corner and went to shift to 4th, that is when I ended up in second. I was going between 50-55 when it happened, no faster as I don't break the speed limit on that road (dangerous road with curves but fun to cruise) So according to another thread based off the gearing ratios, as long as I wasn't over 65 MPH I should be good.
I am hoping at least, I will check out the recommendation on that shop, probably going to do it any way but after Christmas.
AP1 at 8900 rpm:
1st gear: 42.8 mph
2nd gear: 65.6 mph
3rd gear: 90.6 mph
4th gear: 115.5 mph
5th gear: 138.1 mph
6th gear: 165.4 mph <-- theoretical. Limited by aerodynamics without a few hundred extra horsepower.
Old Dec 1, 2015 | 12:44 PM
gfacter's Avatar
I was going from 5th to 6th at VIR at the little bend at the flag stand and went to 4th at 128MPH. I think I was about 100 RPM away from doom. The retainers were not cracked
Old Dec 1, 2015 | 12:51 PM
357MAGNOLE's Avatar
Damn, was that on AP1 retainers or upgraded?
2001-S2k
Jun 3, 2014 08:57 AM
jym89709
Apr 6, 2011 06:28 AM
hondaf1
Dec 24, 2009 05:30 PM
socold57
Feb 14, 2006 01:53 PM
