Baltimore Area Help
Old Mar 11, 2010 | 05:51 AM
jrlandsman's Avatar
Default Baltimore Area Help
Hey Guys, where can I get my block honed in the Baltimore area? I know inline pro is in DC but thats a 2 hour drive I was hoping to be able to get my block done local in Baltimore, I just need it honed any one know of any machine shops around that can do it? Thanks!
Old Mar 11, 2010 | 08:06 AM
HonCBRf2's Avatar
is it that bad that you cant do it yourself? There are self do it honing kits out there that are pretty good.
Old Mar 11, 2010 | 08:44 AM
TopGear's Avatar
Don't know of anywhere myself, but I would ask in the Mid-A subforum.
edit: Hey look, here we are
Old Mar 11, 2010 | 09:17 AM
jrlandsman's Avatar
I wasnt aware that you could hone your block yourself, anyone done this? I found a place called Swanner in northern baltimore that has done some in the past may use them.
Old Mar 11, 2010 | 11:37 AM
HonCBRf2's Avatar
Yes you can, it is very easy to do:
http://www.ehow.com/how_4727370_hone-cylinder.html
Can I ask you why you think you need your block honed? I'm assuming you have you engine tore apart right? How do the cylinder walls look, any deep scratches?
Worse case scenerio, after you hone your cylinder walls you might require a thinker piston ring even if it is thousands of a inch.
Old Mar 11, 2010 | 11:40 AM
jrlandsman's Avatar
yep torn apart, cylinder 4 deep scratches and a lot of them. I am looking at another short block tonight in the Baltimore area that I may buy and get honed because I believe mine are far too deep to take out. Ill take a look at that and see if I may want to hone out the cylindars myself. I know you can do that with most engines but was not sure about our FRM cylinders, anyone honed their own FRM cylinders before?!
Old Mar 11, 2010 | 11:42 AM
HonCBRf2's Avatar
can you feel the scratches?
Old Mar 11, 2010 | 01:30 PM
jrlandsman's Avatar
yeah big time I can feel them real easy, my block def needs to be sleeved, I hope this other one may be able to just be honed
donaldmejr
Sep 4, 2014 09:11 AM
Bunkaking16
Mar 6, 2014 09:41 AM
R.O.C.
May 2, 2010 11:37 PM
jrlandsman
Mar 10, 2010 05:24 AM
AusS2000
41
Mar 19, 2006 01:21 PM
