cusco floor bar
Old Dec 18, 2008 | 12:10 PM
radish03's Avatar
Default cusco floor bar
i got the 3 piece cusco floor bar brace and it didn't come with hardware? do you use stock bolts?? or what?? cusco says "if it doesn't come with it, then you don't need hardware" to me it doesn't make sense.
thanks
scott
Old Dec 18, 2008 | 12:12 PM
bighead's Avatar
what is a floor bar brace? got a link?
Old Dec 18, 2008 | 12:18 PM
radish03's Avatar
http://www.bulletproofautomotive.com/catal...tail.php?ID=318
Old Dec 18, 2008 | 12:29 PM
bighead's Avatar
I don't know much about that item but it seems it mounts to existing mounting points (probably subframe bolts) so I'd imagine you would reuse your OEM hardware. You might want to check the JDM forum for more info.
Old Dec 18, 2008 | 12:31 PM
rudeS2k's Avatar
i have it on my car..It came with 2 bolts and 2 nuts, which you use to attach the 3 bars together and the rest you use the pre-existing oem bolts on the car. here's a pic..not the greatest but you can see the rear pre-existing bolts you need to use.
Old Dec 18, 2008 | 12:39 PM
gfacter's Avatar
Does it do anything?
Old Dec 18, 2008 | 12:43 PM
bighead's Avatar
it's blue
Old Dec 18, 2008 | 12:44 PM
dollar's Avatar
Old Dec 18, 2008 | 12:47 PM
radish03's Avatar
thats what i thought, the other points would use oem parts thanks.
Old Dec 18, 2008 | 02:12 PM
nightcrawler7188's Avatar
i hear this subframe brace makes a huge difference, let us know how it turns out.
