Emmisions in MD
Old May 7, 2008 | 10:40 AM
Revenge's Avatar
Default Emmisions in MD
Is there a problem using the AEM EMS for our cars in MD. Can I pass them with a tail pipe test or is it a real PITA.
Old May 7, 2008 | 11:31 AM
goldenfri's Avatar
Yea you have a problem, they don't do the tailpipe test of OBD-II cars, they plug it in to the OBD port. You need to have the OEM ECU/piggyback or know someone.
Old May 7, 2008 | 12:17 PM
silversurfer05's Avatar
Lower your car as much as possible. I'm running the AEM EMS 1052 and they gave me a 2 year waver because my car was to low to enter the facility.
I hear they are working on a solution with lowered cars. If that materializes the only option is to remove the AEM and buy the new Hondata K-Pro S2000, which is probably better suited for the S2000 anyway.
Old May 7, 2008 | 12:36 PM
goldenfri's Avatar
^^ wow I didn't know that worked for OBD cars too.
Old May 7, 2008 | 02:19 PM
Turtle636's Avatar
If they cant get you over the rollers to reach the OBD II plug in
Old May 7, 2008 | 02:46 PM
nightcrawler7188's Avatar
would it be possible to plug the stock ECU back in right outside, just to go through the test, and then put the EMS back in once you roll out of the garage?
Old May 8, 2008 | 03:49 AM
No, I think you need 10 to 20 days of history reported through the OBD II sensor when they run diagnostics.
Old May 8, 2008 | 06:28 PM
Spoolin18's Avatar
It is impossible to pass with AEM EMS in the state of Maryland unless you know someone. Your only hope is a waiver of some sort, or installing the stock ECU.
Old May 8, 2008 | 06:40 PM
S2Kyle01's Avatar
My car isnt that low (tein stech spings) and the gave me 2 year waiver... they didnt even try they walked outside and told me to park and go inside ....
Old May 9, 2008 | 07:08 AM
goldenfri's Avatar
I am lowered on KWs and they waved me right though, made it though ok, and I'm sure I"m alot lower then a car on s-techs. So it sounds like its luck of the draw.
xGribbyx
Jul 10, 2012 03:02 AM
bobby.is.rad
Apr 15, 2011 03:05 AM
Bullwings
16
Nov 24, 2010 11:58 AM
vietdragontekx
Nov 21, 2010 07:52 PM
ERL_S2000
Nov 23, 2005 01:25 PM
