F20C powered Rx-7 build thread
that is my dyno and yes i installed the injectors but i upgraded to the AEM EMS. still have the emanage siting at home. Inline pro told me i needed a better/ full EMS not just a piggy back to run 12.5psi on a stock block and no headgasket.
when i did the rough estements by setting the motor and tranny in the car, all it will need is a custom subframe. since the f20 is considerably taller then the rotary i need the motor to sit as low as possible so it will clear the hood. the front of the oil pan will hit the front part of the subframe. other then the subframe and motor mounts of course, the tranny lines up right where the rx7 tranny did so no mods there, and no molding/ notching of the side wall is required. its suprisingly an easy fit. it will even leave me with a little more room on the side wall then the S.
