Factory Tint
Originally Posted by s2krazy01' date='Jan 12 2009, 01:31 PM
i'm not sure the equation is that simple. if the factory windows allow x% of light to pass through, and I restrict that light to 20%, i should get the measured 12%. in short, measured tint / applied tint = factory tint.
i have no problem with it being illegal, but thanks anyway.
The window has a maximum opacity of 100%.
The tint you applied has a 20% opacity rating.
The officer measured your window's opacity to be 12%.
The difference in opacity between your tint and the measured opacity is 8%.
Therefore, your window did not start out at 100% opacity but rather 92% (100% - 8%).
Originally Posted by bighead' date='Jan 12 2009, 02:13 PM
nope, it's that simple. You're over analyzing things.
it's not exact but since the factory tint is so close to 100% it can be used as a more accurate model than taking 12% of 20 (which I'm assuming is how you came up w/ 60%)
it's around 3-5% (or 97-95% rather). Which goes along with some tint shops offering 38% to get windows close to 35% which is what the majority of states limit side windows to
Originally Posted by s2krazy01' date='Jan 12 2009, 03:29 PM
i can see how that seems logical, but i'm not convinced. by that logic, 2 sheets of 50% tint on top of each other would = 0%. and that's obviously not correct.
It is that simple when applied as intended to glass. It may not be 100% exactly perfect, but it should be pretty close.
The ratings don't carry obviously when you do something like apply the tint to tint.
Bill's math is right.
You allow 50% in. Then, you add another sheet of 50%. That second sheet allows half of the available light to pass to another sheet that allows half the available light to pass.
100% available light --> 50% tint(resulting light passed = 50%)
Now 100% of light available after the first piece is 50% of the original light source and is filtered through the second piece of 50%. The result? 25%... IF that was the way the items were to be applied.
As it stands, your junk is dark.
