Fuel smell!
hey guys. i uninstalled the comptech setup a while back, and everything is stock and good now (save the fuel pump)...except there's a fuel smell emanating from the front (I think it's from the engine bay). It'll leak into the cabin if I don't have the recirc. switch on, and my fuel economy is down noticeably. the scent is always stronger under braking too.
this all started a few weeks after i've ran stock problems-free. i didn't notice any lines or hoses disconnected, and i'm thinking about rechecking the fuel rail washers. anything else i should look for?
thanks!
oh yeah, any PDR recommendations in the NoVA area?
thanks!
check the injector o rings, where the fuel pressure regualter used to be, also prime the fuel system at check around the pump too. I don't think anything else in the fuel system is touched with a comptech sc
thanks guys. yeah, i used brand new washers when i reinstalled. hmm, i'll just i'll just reinstall everything again and check the orings on the injectors too. i didn't have to tap into anything, and i primed it last time and didn't notice anything.
ahhh, hopefully a warm day will come
I would check the return line. That should be the only line that should have been messed with for the s/c. The return line goes to the FMU, and from the FMU to the fuel rail. Maybe it got a small hole in the line when it was removed/reinstalled.
riceball777
Sep 21, 2011 10:00 AM
WynnS123
Nov 16, 2007 07:46 PM
