Help! Check engine light!
Old Aug 25, 2010 | 06:14 AM
  #21
01S2KBROSNAN's Avatar
Its true.. I think its about 20 on/ offs before it will clear the code. Once it sees that its not a reocurrung problem
Old Aug 25, 2010 | 06:42 AM
  #22
FASTSIIK's Avatar
It will clear itself, assuming the condition that caused the CEL is corrected, in 3 drive cycles. To be safe I wouldn't just disconnect the battery to clear it, at least find out what it is first.
  #23
TopGear's Avatar
Originally Posted by w1ngman,Aug 25 2010, 08:03 AM
Understand that simply tightening the gas cap (assuming that is the thrown code)...does not 'turn off' the CEL. The CEL has to be reset...either by use of the code reader, or by pulling the (+) lead from the battery terminal & waiting a few minutes prior to reconnecting to the battery. Note: If you have a stock radio, you'd want to know the radio code in order to reset it later prior to pulling the battery cable.
There is a fuse for the ecu which you can pull and reset CEL's without resetting your radio. I don't remember which one off hand, but it's mentioned somewhere in UTH.
Old Aug 25, 2010 | 03:41 PM
  #24
Cid00x's Avatar
Just to safe, I am goign to have FASTSIIK look at my car soon to see if he can get the error code, or reset it. He is actually close to where I live, which is Reston.
Old Aug 25, 2010 | 03:46 PM
  #25
TopGear's Avatar
Just being safe would've been going to autozone two days ago, and having them scan it (for free)
Not that FASTSIIK won't be able to do it. I just wouldn't have waited so long. It's such a simple thing to check.
Old Aug 25, 2010 | 04:18 PM
  #26
Budman05's Avatar
If you have no idea what is going on, you should have driven directly to Auto Zone, Advanced Auto, pick the parts place, and had it checked. Just because it isn't flashing, meaning impending doom, doesn't mean you aren't risking getting to that point. It if flashes, you will need to to shut it off on the spot.
Get it checked, or walk. The best thing you can do, is learn some basic mechanical skills and buy and ODBII tester.
These are skills that will last you a lifetime.
Old Aug 25, 2010 | 05:46 PM
  #27
HMFIC's Avatar
eggzachary...I've got an obdII scanner i carry in my daily.
Old Aug 27, 2010 | 09:04 PM
  #28
Cid00x's Avatar
Right...so I just thought I should update you guys. The CEL went away. Lol. IDK how. Maybe its that whole starting it 20 times or something, but I check like at around 9 pm and and it was gone..lol.
Old Aug 28, 2010 | 06:43 AM
  #29
Nandska's Avatar
May still be a good idea to see what it was. Next time, it may come up blinking.
But either way, good to see it's gone.
Old Aug 28, 2010 | 06:51 AM
  #30
More then likelly it was just ur gas cap then.. but next time don't eff around get a scanner on it asap!
Check out summit racing. I bought one fromm themm for 60 bucks.. hasn't ?et me down yet.
