Need help with hood!
LOL oh man i am kinda whipped somethimes...i mean youre like 477th person to tell me that hahah
oh and allan! thats exactly what i was looking for!!!! oem lip wing vented hood and hardtop!! but yeah will someone help me vent the hood
ok...........i actually didnt use the tools that the FORUM said to use.
I'm very good with a dremmel tool........for some reason i have very steady hands Giggity....
So what i did was... i took a bit from my screw driver set.. you know.. that peice you can interchange to use as a screw driver? Well i just placed it right up against the skeleton, took a marker and just placed it right up to it, and just moved the peice all the way around the skeleton and thats how i traced it....looked like i was playing with a oieji board but with a marker and tool bit hahaha...
I then took my drill, and on each corner, i drilled a couple of holes in each corner all did that for all the shapes............then with my dremmel, my trusty hands and sitting on my big ass balls, i just started to dremmel away.... made the shape smooth.....did all 6, and i was done.
that FIRST initial hole you drilled is the worst........but once you started hahahahaha.. doh well... might as well keep goin. So i did
Anfony was there the whole time too......shaking his head at me hahahaha.
Originally Posted by FF2Skip,Jul 16 2008, 04:40 PM
You're correct; it's not easy to lose weight on the S. EJ was on the right track.
Replacing the enitre exhaust(header, cat, exhaust) nets a potentially significant loss. When I ran the Rick's header and the T1R 70RT, I saved at least 60 lbs. The downside of this(not applicable on the street) is that weight is removed from a relatively low point on the car, thereby raising the car's center of gravity.
Lightweight battery. For approx. $175, you can have a 14lbs battery. That may be approximately 10lbs saved.
The softtop assembly is approximately 70-75lbs. OEM hardtop weighs about 44 lbs. You save 30lbs and decrease drag. My current hardtop weighed in near the 15-pound mark. Unfortunately it is a little heavier now that I repaired it.
Trunklid is not aluminum like the hood. Weight can be saved there even with pseudo-CF ones.
Wheels are a great place to shave weight, but most times, it'll cost you.
Airbags are heavier than I thought, but most on here street their cars. I DO NOT recommend removing your airbags if you drive on the street. It's illegal.
Spare tire/tools.
Seats.
Carpet.
Stereo/speakers.
Spare tire/tools.
Seats.
Carpet.
Stereo/speakers.
sunhita
35
Aug 26, 2008 08:51 AM
